NCS WLAN Configuration Template Problems
jayjotoronto
Community Member
Hi All,
I'm trying to set up WLAN Configuration templates on our new NCS server.  The version of NCS is 1.1.1.24 and the version of our WLC is 7.2.103.0.  I have two problems:
1.  I do not see an option for AAA Override.   Has this been renamed to something else in NCS?
2.  I do not see a way to assign a WLAN ID in the template.  This is important as I use it as a RADIUS attribute in our ClearPass guest wireless service.
Jason
Stephen Rodriguez
Yeah, it's a bit hidden.
For the AAA Overide, it's actually under the Security > AAA Servers.
As for setting the WLAN ID, this is not a configurable option from NCS.  It will just build the next one that is available.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
Steve,
There it is!  Thanks very much.  It's too bad about the WLAN ID.  I'll just have to configure that one SSID manually or use a different RADIUS attribute.... maybe Station-ID.
Thanks again,
Jay
