Bringing wireless to a Campus
randyclark
I am wanting to add wireless to our campus, but I also want to protect our wired network. The powers that be also want a single login for our clients (students with differant types of wireless cards).
I am looking at using the 1200 series APs
Could I add an port to my firewall and put the APs on a seperate vlan and treat the APs as an untrusted network?
Also could I use a RADIUS server to authenticate the wireless users with active directory accounts from another server?
blue.modal
Radius proxy will give you single sign-on.
If you put all of the APs in a subnet separated from your wired network by a firewall (you can use trunking between switches to avoid pulling a whole new cable plant) you can achieve what you are after.
Alternately, you can use a multi-layered security approach to protect APs directly on the wired subnet. A VPN on top of WEP and a MAC Address filter would protect you well.
Matthew Wheeler
Chief Wireless Architect
Blue Modal, Inc
www.bluemodal.com
blue.modal
Matthew Wheeler
Blue Modal, Inc
www.bluemodal.com
