Broadcast SSID on foriegn NCS system
F4ttie
We are a Scottish Local Authority and have NCS prime system, 2 of 7500 controllers with 1500 AP's ; working in Flex connect mode. Our local NHS has NCS prime and 7500 controllers. We want to co-host an SSID anchored on the others system. I recollect a Cisco paper on this but can find no help.
We currently have a VPN to our local NHS and I understand that we will anchor the SSID on the alien system and will have to agree an IP structure that works for us both..
Anyone done this? Any help would be greatly appreciated
Michael
See if this link helps you on this
Rasika
*** Pls rate all useful responses ***
Rasika
Thank you for that. Exactly what I need.
The only problem we now have is the fact that we use Hreap for local breakout on our access points. As we do not share the same VLAN infrastructure as the NHS can I just amend the SSID on the NHS side to break out at the controller on our side?
