Building to Building wireless
nsiddiqui
I have T1 to my remote location. I am less than a mile away from the remote location. I can clearly see from building to building. I am looking some solution where I can provide high speed network to my remote location. T1 speed is not enough to transfer the images. I am thinking to go with wireless AP1200, if I use AP1200, how far I can go, other option I am thinking are use dark fiber (if it is available) or satallite. I will appreciate any help.
r.waldron
First of all what is in your buget to this project..there are lots of solutions.that can carry gbit files.
Money is not an issue, I need the best possible solution.
ndoshi
If it is < 1 mile and line of sight , one possible solution is to use BR350 . We have 3 non overlapping channel 1 , 6 and 11 so you can install 3 pairs of Br350 to get more throughput .
Only thing is it works on unlicense band so risk of interference .
You can NOT use AP in Bridge mode
