10-08-2009 12:20 AM - edited 07-03-2021 06:07 PM
Hello
I Want to connect building represent the H.O with 2 buildings acts as branches using wireless technology ,I have 3 bridges(1200 series) at each site with parabolic dish's now I need a help to design and implement and configure such this project, PDF Describe such this project is very much appreciated
10-08-2009 05:44 AM
It is almost impossible to give you a detailed answer without more information about the site... this document may help you:
As for the antennas, please keep in mind that your H.O. will need to send and receive from 2 sites, so I am not sure if a parabolic dish, which is very "point to point" (very narrow beam) will be the best one... I would expect more an omni or sector antenna at the HO site, but it depends of course on the distance to the branches.
Have a look at this document, it will give you the antenna beam shapes:
Hope it helps
Jerome
10-15-2009 12:34 AM
hello
didn't open,it needs valid account from cisco,pls can u attach it as PDF
10-15-2009 01:00 AM
Try again. The links provided are freely available to anyone without a CCO account.
10-21-2009 12:57 AM
hi
what i received
The file or application you are trying to access may require additional entitlement or you are trying to access a file with an invalid name. Additional entitlement levels are granted based on a users relationship with Cisco on a per-application basis.
If you feel you have reached this page in error, please try one of the following methods to locate your document:
If you are manually entering the URL into your browser location bar, be sure to include the file name of the page you are trying to access (file names typically end in .htm, .html or .shtml).
Use the Search feature located in the upper right section of this page.
Return to the Cisco.com Home or select a primary site area from the top navigation bar.
Consult with your Cisco Account Manager to confirm you have the appropriate entitlement to access this page.
If you would like to contact someone about this problem, please click on the Contacts & Feedback link below.
Back
