Bundling 2 wireless 1300
Hi all
i have 4 1300AP/BR i want to connect my branch office which is 3 km away.i have 4 1300 equipments with 12 dBi antenna 2 no's and 13.5 dBi antenna 2 no's.is it possible to put 2 1300 at H.O and 2 at Branch .and one will give you 54 mbps , so if i put 2 equipments at each site is it possible to attain 100mbps i mean bundling, is it possible.
i will appreciate any inputs
Thanks & regds
Binoy.
ebreniz
Level 11
Level 11
You can make use of PAgP with wireless , but not that direct.
Try out the below document.
http://www.cisco.com/en/US/about/ac123/ac114/ac173/ac170/about_cisco_packet_department09186a008010176b.html
ulstegner
Cisco recommend to use a channel over both Rf Links.
A other way is a L3 connection with a routing protocol or a L3 Channel :
if port-channel 1
ip address ....
int fast 0/1
channel-group 1
int fast 0/2
channel-group 1
regards Ulrich
