business wireless
Jpoulos07
Community Member
Hello, I need some help purchasing the correct equipment for my sports facility. LAN is already setup and configured all we need to add is a wireless option with a main and guest network. We have 42,000 square feet in one large open gym. Also we need to support up to 2700 people at a time on the guest network as well has have our employees connected to our main network at the same time. Any help would be appreciated. Thanks.
Bob Bagheri
Level 4
Level 4
John,
I recommend a site survey for starters.  From there a Cisco controller and the number if AP's recommended by the survey should be adequate to get started.  There are many more questions I can think of, so if I was you, i would contact a qualified Cisco partner for assisstance.
Re,
Bob Bagheri, CCNP-W
