04-07-2013 12:58 PM - edited 07-03-2021 11:51 PM
Hi;
It is possible to apply a limit of bandwidth per SSID using the WLC?. In case of not being possible, is it possible to apply for Access-Point?
Solved! Go to Solution.
04-07-2013 03:18 PM
Firmware 7.0.X can limit bandwidth on a per user level.
Firmware 7.4.X can limit bandwidth on a per user or per SSID level.
04-07-2013 01:41 PM
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080bd3900.shtml
with wism, 4400, 5500, WiSM2,.. supports to limit bandwdith per user/ssid/interface on downlink, the later code supports bidirection rate limiting using software.
wlc like 2500, sre, vwlc doesn't support bandwidth contract.
Currently only 5760 & 3850 can do very granular per user/wlan/radio/ap level line ratelimiting using hardware.
04-07-2013 03:18 PM
04-07-2013 04:56 PM
Thanks for the answer. We use 5500 WLC. I am looking the release notes of 7.4.1 firmware ( http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn74.html ) and i dont see per wlan rate-limit as a feature.
Where i can find some documentation?
04-07-2013 05:43 PM
Take a look at this link
http://www.cisco.com/en/US/docs/wireless/controller/7.4/configuration/guides/system_management/config_system_management_chapter_01110.html
04-08-2013 07:36 AM
Thanks you very much
04-10-2013 11:24 AM
Well, 7.0 can still do per user and per ssid bandwidth control, the downside is qos profile configured for wireless que is locked to those 4 profiles. Ex: Besteffort profile que configured with X value configured on global config can be applied to one wlan, if different wlan require different throttling then that can't be done. And per user works only if the user is linked to the configured profile, so there is no mehanism to fair share the available bandwidth among the clients on that wlan.
04-10-2013 06:10 AM
As per your query i can propose the solution-
Yes it is possible to apply a limit of bandwidth per SSID using the WLC.
