Bypass SSL Certification Before Going to Web Passthrough
amolhempour
I have WLC 2106.
i have it setup as webpassthrough.
anytime someone wants to connect it asks for certification in IE.
is there any way I can bypass the cert so when you open IE it would take you to passthrough page ?
paul.ward
If you are using the WLAN for a guest type of access you will probably want to purchase a public SSL cert. Vendors like Entrust, Verisign and RapidSSL are ones I have used in the past.
paul.ward
Paul is right.... here is a link that you can use:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00806e367a.shtml
-Scott
Note:
No Support for Chain Certificate
WLC is not a root certificate authority server. WLC does not have the functionality now to proxy communication of a chain certificate with a root certificate authority server. In order to host a chain certificate you must be a root certificate authority server.
IE: Don't buy a super cheap one like from GODADDY. It won't work without having to trust the root cert first.
