08-22-2023 03:57 PM
Can I use this antenna with 5GHz?
Is 802.3bt required?
I want to install it for a warehouse at one end, replacing ANT2566P4W-RS=
I have RF devices 1x1 stream
Please, I would appreciate your answer
Solved! Go to Solution.
08-29-2023 12:18 PM
Hi @PQR
I believe this is not right, otherwise there would not be a use case for this antenna as 99% (if not 100%) of end devices on the market does not support 8x8.
08-22-2023 04:37 PM - edited 08-22-2023 04:39 PM
Hi @PQR
This antenna is in the list as supported antenna for AP C9130e and it does support 2.4 and 5.0ghz.
The fact that the device is only one spatial stream is not a problem.
External antennas supported on the Cisco Catalyst 9130E
Table 3. External antennas
Part number |
Description |
Gain |
C-ANT9101= |
Ceiling Mount Omni Self-Identifying Antenna with Bluetooth, 8-port, with DART connectors. |
4 dBi (2.4 GHz) 4 dBi (5 GHz) |
C-ANT9102= |
Pole or Wall Mount Onmi Self-Identifying Antenna with Bluetooth, 8-port, with DART connectors. |
C-ANT9103= |
Pole or Wall mount 75° Directional Self-Identifying Antenna with Bluetooth, 8-port, with DART connectors. |
6 dBi (2.4 GHz) 6 dBi (5 GHz) |
AIR-ANT2513P4M-N= |
Patch Antenna, 4-port, with N connectors Note: Connect to AP using AIR-CAB003-D8-N=. |
13 dBi (2.4 GHz) 13 dBi (5 GHz) |
AIR-ANT2524V4C-R |
Ceiling Mount Omni Antenna, 4-port, with RP-TNC connectors Note: Connect to AP using AIR-CAB002-D8-R=. |
2 dBi (2.4 GHz) 4 dBi (5 GHz) |
AIR-ANT2524V4C-RS= |
Ceiling Mount Omni Self-Identifying Antenna, 4-port, with RP-TNC connectors. |
AIR-ANT2544V4M-R |
Wall Mount Omni Antenna, 4-port, with RP-TNC connectors. Note: Connect to AP using AIR-CAB002-D8-R=. |
AIR-ANT2544V4M-RS= |
Wall Mount Omni Self-Identifying Antenna, 4-port, with RP-TNC connectors. |
AIR-ANT2566D4M-R |
60° Patch Antenna, 4-port, with RP-TNC connectors.1 Note: Connect to AP using AIR-CAB002-D8-R=. |
AIR-ANT2566D4M-RS= |
60° Patch Self-Identifying Antenna, 4-port, with RP-TNC connectors |
AIR-ANT2566P4W-R= |
Directional Antenna, 4-port, with RP-TNC connectors. Note: Connect to AP using AIR-CAB002-D8-R=. |
AIR-ANT2566P4W-RS= |
Directional Self-Identifying Antenna, 4-port, with RP-TNC connectors |
08-22-2023 04:40 PM
Hi, thanks for your answer
I see that it does support it
C9130E with C-ANT9103=
08-22-2023 04:42 PM
Yes, it does. You can see on the list I shared also.
08-22-2023 04:53 PM
Yes,
thanks,
I found this statement on twitter and I did not understand what it means, I also ask if it is required to work with Universal POE (802.3bt).
The twitter says: "Disappointing it cannot do dual 4x4 5Ghz"
08-22-2023 05:11 PM
This antenna is Tri-band MIMO Wall/Pole mount directional antenna operates in the 2.4-, 5- and 6-GHz frequency ranges and supports IoT.
The dual 4x4 5,ghz is not mentioned on the datasheet thus is not supported. But I believe this feature (dual 4x4 5Ghz) is supported on internal antennas. Like, for example the 9124AX
Cisco Catalyst 9124AX Series Outdoor Access Point Features
Cisco Catalyst 9124AX Series Outdoor APs are supported on Cisco Catalyst 9800 wireless controller-based
products, and have the following features:
• Two radios—a dual-band 5-GHz (4x4) flexible radio with 2.4-GHz and 4x4 5-GHz radio, and an Internet
of Things (IoT) radio that works with Bluetooth Low Energy (BLE) and other multiprotocol 802.15.4
devices.
About the PoE, the antenna does not required PoE or extenal power source. Antennas are passive device. On this case, the antenna has a Led but the power comes from the AP.
08-22-2023 05:17 PM
thank you very much for your response,
I didn't understand much about 4x4 5GHz, so with the C-ANT9103 antenna only works in 8x8 5GHz?
Will it impact the 5GHz performance for my devices?
I was referring to the AP 9130E, if it is necessary to work with the antenna, because I see that it says that for 8x8 it has to be 802.3bt, and with 802.3at it would only work with 4x4 in 5GHz, so I was worried about what the tweet says.
08-22-2023 05:33 PM
What the guy was reffering to is Dual 4x4. Which means, the same antenna propagates two 5.0ghz radios with 4x4.
At least, thats what I undertood. He might be talking about flex radio
About the PoE, on the datasheet, you can see 802.3at also
Cisco Catalyst 9130AXE |
PoE power consumption |
2.4-GHz radio |
5-GHz radio |
Link speed |
USB |
LLDP |
802.3at (PoE+) |
4x4 |
8x8 |
5G |
N |
25.5W |
802.3at (PoE+) |
4x4 |
4x4 |
5G |
Y [4.5W] |
25.5W |
802.3bt (Cisco UPOE) |
4x4 |
8x8 |
5G |
Y [4.5W] |
30.5W |
08-29-2023 10:29 AM
Hi @Flavio Miranda ,
thank you very much for your response, sorry for the delay in replying.
I found this information, when the datasheet says it only supports 8X8 antenna, does it mean it only supports 8X8 client devices?
Will it support 1x1, 2x2 OR 4x4 devices?
08-29-2023 12:18 PM
Hi @PQR
05-13-2025 05:14 PM
Does the C-ANT9103= Include the Wall/pole mount hardware or is that a separate item to purchase?
