C/C++ Error When Starting WCS
DrewShrider
Visitor
Background information:
WCS version 7.0.230.0
Red Hat Enterprise Linux Server release 5.9 (Tikanga)
I am unable to successfully start all of the services for WCS.  This is a fresh install.  Here's what the log says (from launchout.txt):
JAVA_HOME=./../jre
Checking for Port 21 availability... OK
Checking for Port 8456 availability... OK
Checking for Port 8457 availability... OK
Checking for Port 1299 availability... OK
Checking for local Port 1299 availability... OK
Checking for Port 6789 availability... OK
Checking for local Port 6789 availability... OK
Checking for UDP Port 69 availability... OK
Checking for Port 8005 availability... OK
Checking for UDP Port 162 availability... OK
Checking for Port 8009 availability... OK
Starting RMI registry on port 1299
Registry started.
Key entry exists; Update Apache config from Keystore
Configuring Apache server for key
DB is already started
Starting NMS Server...
ERROR: C/C++ Graphics Library applications require that a DISPLAY be available.
I have searched through the community but I've been unable to find anything on this yet.  Any help would be greatly appreciated.
micsteiver
Frequent Visitor
Frequent Visitor
Same issue for me.
And in the hm-1-0.log. I see :
INFO  [general] [Thread-10] /mnt/cisco/opt/WCS7.0.240.0/webnms/../bin/startServer.sh: line 67: [: too many arguments
Any idea ?
