Answers required for CISCO Wireless Type Approval AP1242G-A-k9
aakashojha
Hi there,
I need few answers to below listed Cisco wireless device - AIR-AP1242G-A-K9 questions- Please help, as these are required for CISCO DEVICE TYPE APPROVAL in my country. The device is AP1242G-A-K9
1) RF channel Spacing: __________________________________________________
2. Type of Modulation: ___________________________________________________
3. RF Output Impedance: ________ ohms
4) Operating Frequency range (switching range without retuning)
a. Transmit: _____MHz to ______MHz; Receive: ______MHz to ______MHz; Max EIRP: _____dBm
b. Transmit: _____MHz to ______MHz; Receive: ______MHz to ______MHz; Max EIRP: _____dBm
c. Transmit: _____MHz to ______MHz; Receive: ______MHz to ______MHz; Max EIRP: _____dBm
d. Transmit: _____MHz to ______MHz; Receive: ______MHz to ______MHz; Max EIRP: _____dBm
5) Functional Description with circuit Diagram at least in Block Diagram Form- AIR-AP-1242G-A-K9
6) Radio, EMC, SAR, Safety Test reports/Certification by the manufacturer or the authorized representative of the manufacture from the country of manufacture/origin
Aakash.
Leo Laohoo
Aakash san,
I recommend you contact your local Cisco SE in Wireless as the supporting documentations you seek.
AIR-AP-1242G-A-K9
Wait a minute ... Exactly, what country will this model of AP be deployed?  If the country is JAPAN, then you are/will be using an AP with the wrong regulatory domain.
Please refer to Wireless LAN Compliance Status.
Hey Mate,
Thanks for your concerns, we are located in Nepal
I got the documents noted on Point No. 6 from Cisco SE. Could any body just provide Block Diagrams and answer the question raised No. 1, 2, 3 and 4.
Aakash.
