C3750 max poe per port
I have just realized that the C3750 switch only seems to support 15.4 watts per port which isn't sufficient for the AIR-AP2702E-UXK9 to run a full power
Any help with increasing this would be very helpful, thank you in advance.
Ed
Please rate all helpful posts. Was the issue resolved? (Mark as "Answered")
Ric Beeching
Level 7
Level 7
What is the full model of the C3750 switch you have? E.G C3750-24PS?
The 3750 series is only 802.3af compliant which maxes out at 15.4W.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-series-switches/product_data_sheet0900aecd80371991.html
In order to provide higher than 15.4W power you can either replace the switch (expensive) or purchase a power injector or local power supply for the 2702E. The recommended power injector is a AIR-PWRINJ4=
If you use either make sure you disable PoE on the switchport that the AP/Power injector is plugged into.
Please rate helpful / correct posts
