C9115 - ssh and wlc join problem
Fernandes
Hi guys,
I have 30 C9115AXI.
When I connect them to the network, I see them with cdp, I can ping, but it does not join the controller. I can't even make an SSH connection.
When I connect with the console and write the ip address of the controller, the problem is solved, but since all access points are mounted, it is very difficult to do this to all of them.
Is there any way to solve this problem?
Device ID: AP6C8D.********
Entry address(es):
IP address: 10.100.*.*
IPv6 address: FE80::6E8D:77FF:*****:***** (link-local)
Platform: cisco C9115AXI-E, Capabilities: Router Trans-Bridge
Interface: GigabitEthernet1/0/1, Port ID (outgoing port): GigabitEthernet0
Holdtime : 158 sec
Version :
Cisco AP Software, ap1g7-k9w8 Version: 8.10.130.0
Copyright (c) 2014-2015 by Cisco Systems, Inc.
advertisement version: 2
Power drawn: 18.900 Watts
Power request id: 5157, Power management id: 2
Power request levels are:18900 15400 0 0 0
Management address(es):
docjb0221
Level 2
Level 2
Does your DHCP scope have option 43 set in hex with the management IP address of the controller?
docjb0221
Level 2
Level 2
Thank u so much, after adding Option 43 value the issue was resolved
Rich R
What model of controller?
What version of software?
Are the APs on the same subnet as the WLC or routed from another subnet?
If routed then as @docjb0221 says you need a method for the APs to discover the WLC.
https://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/119286-lap-notjoin-wlc-tshoot.html#anc5
DHCP Option 43 is the method most of us use.  You can specify 1 or more WLCs for the AP to attempt to join.
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/97066-dhcp-option-43-00.html#anc9
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
