C9120AXI-D not able to configure
I have newly purchased C-9120AXI-D to strengthen my office wifi range. I am not able to configure it.
I do not have Wireless controller for the same, I need to configure as a stand alone device
8 Replies 8
were you able to connect via Console port to CLI?
if so what is the output you are getting?
Good luck
KB
Yes, I am able to connect via console.
But, if I put command "Configure Terminal" then below mentioned message is showing
#configure terminal
% Invalid input detected at '^' marker.
can you share output for #show version
Good luck
KB
Please find the show version output as requested
>show version
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
Cisco AP Software, (ap1g7), C9120, RELEASE SOFTWARE
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Wed Jul 29 02:25:25 PDT 2020
ROM: Bootstrap program is U-Boot boot loader
BOOTLDR: U-Boot boot loader Version
AP1XXXXXXXXXXXXX uptime is 0 days, 0 hours, 18 minutes
Last reload time : Thu Aug 19 05:17:49 UTC 2021
Last reload reason : Capwap Discovery Failed
cisco C9120AXI-D ARMv8 Processor rev 0 (v8l) with 1875408/1086416K bytes of memory.
Processor board ID FGLXXXXXXX
AP Running Image : 8.10.130.0
Primary Boot Image : 8.10.130.0
Backup Boot Image : 0.0.0.0
Primary Boot Image Hash:
Backup Boot Image Hash:
1 Multigigabit Ethernet interfaces
2 802.11 Radios
Radio Driver version : Broadcom BCA: 17.18 RC2.0
Radio FW version : 24203.103.r40354 0
NSS FW version : NA
Base ethernet MAC Address : XXXXXXXXX
Part Number : 0-000000-00
PCA Assembly Number : 074-124XXX
PCA Revision Number : C0
PCB Serial Number : FOC253XXXXX
Top Assembly Part Number : 074-124XXXX
Top Assembly Serial Number : FGLXXXXX
Top Revision Number : A0
Product/Model Number : C9120AXI-D
AP is running capwap image, this will require a WLC to manage this AP. Covert it to EWC as per my previously shared guides.
Please check below result
APXXXXXXXXXXXX#ap-type ewc-ap tftp://0.0.0.0/Cisco/ap1g7 tftp://0.0.0.0/Cisco/C9800-AP-iosxe-wlc.bin
Starting download eWLC image tftp://0.0.0.0/Cisco/C9800-AP-iosxe-wlc.bin ...
It may take a few minutes. If longer, please abort command, check network and try again.
[*08/19/2021 08:55:36.2800] # # #
[*08/19/2021 08:55:36.2800] CAPWAP State: Discovery
[*08/19/2021 08:55:36.2820] IP DNS query for CISCO-CAPWAP-CONTROLLER.xyz.abc
[*08/19/2021 08:55:36.5650] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*08/19/2021 08:56:05.9290] # ##
[*08/19/2021 08:56:05.9290] CAPWAP State: Discovery
[*08/19/2021 08:56:05.9300] IP DNS query for CISCO-CAPWAP-CONTROLLER.xyz.abc
[*08/19/2021 08:56:06.2170] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
-=O=- # # # #
curl: (28) Error
%Error opening tftp://0.0.0.0/Cisco/C9800-AP-iosxe-wlc.bin (Error 28: Operation timeout)
You need to have a working TFTP server and required image files downloaded from Cisco Software download portal. I would recommend to seek professional help if you are not aware of the TFTP upgrade process.
