C9800-L-C-K9 Compatibality with AIR-AP1832I-E-K9C and AIR-CAP1702I-E-K
sithum
We are currently using the AIR-CT2504-5-K9 wireless LAN controller (WLC), which reached its end of support in April 2023. Consequently, we are looking to replace it with the C9800-L-C-K9 model instead of the AIR-CT2504-5-K9. Currently, we have deployed the AIR-AP1832I-E-K9C and AIR-CAP1702I-E-K9 access point models. According to the datasheet, these access points can join the C9800-L-C-K9 controller. However, I would like to confirm this to ensure compatibility.
marce1000
  - Ref : https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
    Lookup compatible software versions for the APs you are using IOS-XE 17.9.3 for instance will be ok,
 M.
marce1000
 M.
