C9800 PKI Management with Wildcard Certificate
james.kuo
Dear All,
Here is my facing problem.
I have a wildcard certificate applied from a third-party CA Authority,
according to the configuration file, I can't find the steps for installing it for Web Admin and WenAuth.
Does anyone have some experience with wildcard installation for C9800 PKI Management?
James Kuo
HsinChu, TAIWAN
13 Replies 13
marce1000
  - FYIhttps://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213917-generate-csr-for-third-party-certificate.html
 M.
Hi Marce,
I have tried this configuration, but still need to generate CSR to sign.
I want to do like the web auth certificate of AireOS.
Upgrade the wildcard certificate to webauth certificate directly.
James Kuo
HsinChu, TAIWAN
Hi Flavio,
I have tried this method, you can see steps 3,
still need to generate CSR and use the local CA Server to sign the CSR.
James Kuo
HsinChu, TAIWAN
 If you have a CA authority, as I believe you do as you said above: "I have a wildcard certificate applied from a third-party CA Authority,"
 What you need to do is go to step 1,2 and 3, get the CSR from the WLC and ask you CA authority to sign it.
After that, install the certificate you get from your CA authoriry, step 5 and 6.
Hi Flavio,
Maybe I didn't make it clear.
I have a wildcard certificate like *.mydomain.com,
I want to use it and upload it to WLC directly without generating CSR.
Because I upload the wildcard certificate to the AireOS webauth certificate, it work.
James Kuo
HsinChu, TAIWAN
Got it, you was clear, I misunderstood.  For that, you need a different approach
You need to install OpenSSL version 1.X ( windows)
Split the PFX file into individual files
Combine all the certificate and private key files to a .PFX file again using OpenSSL version 1.X
openssl.exe pkcs12 -export -in ID-CERT.cer -inkey PRIV.key -certfile CA-CHAIN.pem -out CERT-and-KEY.pfx
On the WLC gui, go to
Configuration > Security > PKI Management > Add Certificate > Import KCS12 Certificate)
wildcard certificate config in WLC ?
are the domain name is same in WLC and users ?
share the domain name and wildcard domain name
Hi MHM,
WLC domain name and wildcard CA name are the same.
James Kuo
HsinChu, TAIWAN
james.kuo
Hi all,
The issue is resolved today, the customer sends me a new wildcard certificate whose format is *.pfx,
upload to WLC may show the root CA & root Chain CA etc... then assign to webauth successfully.
James Kuo
HsinChu, TAIWAN
Hi @james.kuo
 If you received  pfx file, it means they might ran the command I sent you before.
But, the important is that you fixed the problem.
Thanks for let us know.
Hi Flavio,
 My customer downloads pfx from a third-party CA Authority directly,
so I think he doesn't use the command you provide,
but I think the command can resolve the issue when he downloads a different format CA.
Anyway, thanks for kindly replying and providing solutions.
James Kuo
HsinChu, TAIWAN
