Sensor 1800s
SMI3891
Frequent Visitor
Frequent Visitor
I have sensors that claimed to DNAC and running while on wireless backhaul, but I am not able to ping them or SSH, even I have enabled the SSH. Also when I try to connect them through wired on a vlan has dhcp enabled option 43 still unreachable on dnac.
any suggestion please
5 Replies 5
Hi @SMI3891
 Make sure you added the option 43 corectly on the DHCP server and most important if the DHCP server does support it
The string should look like this:
5A1N;B2;K4;I<Cisco DNA Center IP Address>;J80
The problem with Option 43 is that sometimes DHCP servers vendors implement it differently and this can cause troubles.
If you are using a Cisco switch or router as DHCP server, you can find an example config on cisco docs like this one
ip dhcp pool vlan30
network 30.30.0.0 255.255.0.0
default-router 30.30.0.1
dns-server 100.100.100.11
option 43 ascii 5A1N;B2;K4;I100.100.100.80;J80
Leo Laohoo
What firmware is DNAC on?
What firmware are the 1800s on?
SMI3891
Frequent Visitor
Frequent Visitor
@Flaf thank you for the info, I have implemented option 43 on a Microsoft server and I have used the schema used on the deployment guide.
@Leo Laohoo I am using dnac 2.3.3.7 and the 1800S was on 1.3.3.3 and now 2.3.3.3
SMI3891
Frequent Visitor
Frequent Visitor
Also, the wireless sensor shows 10% of the claim progress
This means then the Sensor contacted  DNAC and is trying to join. I had this problem too and I had to repeat it some times until I got the sensor claimed.
