C9800
CruzBarrera
Level 2
Level 2
 I'm going to update a C9800 from version 17.9.4a to 17.15.2. Is a direct update possible, or do I need to install an intermediate version?
2 Accepted Solutions
Mark Elsen
  - @CruzBarrera                  FYI : https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-15/release-notes/rn-17-15-9800.html#Cisco_Concept.dita_59a2987f-2633-4630-8c7b-a8e8aecdeaf7
17.9.1 to 17.9.5
Upgrade to 17.9.6 or later or 17.12.x or later, and then to 17.15.x
Upgrade directly to 17.15.x
   Actually 3d column : Upgrade Path for Deployments Without 9130 or 9124
   (sorry for multiple iterations)
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Leo Laohoo
Reboot all the APs first before doing the upgrade to maximize the chance of avoiding CSCwe15172, CSCwe97901, CSCwm08044, CSCwm07499, CSCwm72142, CSCwo05017.
Next, after upgrading to destination version, make sure to install APSP to fix  CSCwf37271 & CSCws70285.
7 Replies 7
Mark Elsen
17.9.1 to 17.9.5
 M.
Thaks so much...
Leo Laohoo
A field notice has been released for the cnssdaemon.log problem now:
Field Notice: FN74383 - Cisco Access Points Running Cisco IOS XE Releases 17.12.4, 17.12.5, 17.12.6 or 17.12.6a May Run Out of Flash Space, Preventing Upgrades - Software Upgrade Recommended
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Thanks, @Rich R.
I suspect the number of TAC & RMA cases forced Cisco to reluctantly release this FN.
CruzBarrera
Level 2
Level 2
Thanks a lot Leo
Rich R
@CruzBarrera  refer to TAC recommended code versions (link below).  If you're going to 17.15 then you should be going to 17.15.4d + latest APSP.
17.15.5 will likely replace that soon.
