Cable distance
tookenyip12
Community Member
i hope someone will be able to help me out. I'm trying to deploy an AP with a max range from the switch >100m. The question is can i pull a 100m cable from the switch to the power injector and another 100m from the power injector to the AP?
switch --------(100m cable)------------ pwrinj3 --------(100m cable)------------ AP
I hope i actually explain this clearly. thanks for the help in advance.
kirchhoffpolska
Yes you can
I use such configuration. About 150 m whole distance and it works with no problem
kirchhoffpolska
Yes you can
