Can AIR-AP2802I-F-K9 join WLC C9800
Dear Cisco Community,
Please kindly advice my customer have existing APs AIR-AP2802I-F-K9
and they want to refresh the WLC to C9800-L-C/K9
can the existing access point join to the new WLC and get the Wifi6 ?
if yes, do you have any specific documentation for the integration tutorial
Thank you
Mark Elsen
                 >...can the existing access point join to the new WLC and get the Wifi6
 No because that capacity is  a property of the particular access point model , which can only do up to  802.11ac
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Dear Marce,
Thank you for your kind reply,
ok I got it that the existing AP can get Wifi 6 but they are still able join to WLC 9800 if we buy the AIR-DNA License?
CMIIW
Thank you
        - Yes , you will be able to use the AIR-AP2802I-F-K9  on the C9800-L-C/K9
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Leo Laohoo
9800 controller will be able to support 2800.
2800, however, does not support 802.11ax/WiFi 6.
