Can catalyst 9124ax join mobility express controller
adeebtaqui
Level 4
Level 4
Greetings,
We had deployed mobility express for wireless complrising of 2800  1800, 1542  6300.
But now we have to replace one faulty 1542 and as this is end of sale - catalyst 1542 is the optio
Can 9124ax join existing mobility express or should we go for embedded controller on 9124 and them make it as controller and all mobility express wireless access points as part of embedded controller
Leo Laohoo
There is no plans for 9124 to be supported in AireOS nor Mobility Express.
From Cisco 9124AX datasheet:
Cisco APs Supported in Cisco Embedded Wireless Controller on Catalyst Access Points
Primary AP
Subordinate AP
Cisco Catalyst 9115 Series
Cisco Catalyst 9117 Series
Cisco Catalyst 9120 Series
Cisco Catalyst 9124AXE/I/D
Cisco Catalyst 9130
Cisco Catalyst 9105AXI
Cisco Aironet 1540 Series
Cisco Aironet 1560 Series
Cisco Aironet 1815i
Cisco Aironet 1815w
Cisco Aironet 1830 Series
Cisco Aironet 1840 Series
Cisco Aironet 1850 Series
Cisco Aironet 2800 Series
Cisco Aironet 3800 Series
Cisco Aironet 4800 Series
Cisco Catalyst 9130
Cisco Catalyst 9105AXW
Cisco Catalyst Industrial Wireless 6300 Heavy Duty Series Access Points
Cisco 6300 Series Embedded Services Access Points
Reference Link:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/17-9/rel-notes/ewc-rn-17-9-x.html#Cisco_Concept.dita_4e686689-db5f-464b-8157-92abcfd40028
Jagan Chowdam
/**Pls rate useful responses**/
Thanks @jagan.chowdam for sharing. Will we then need to reset all 30 plus mobility express access points for joining the embedded controller on 9124AX?
       >...Will we then need to reset all 30 plus mobility express access points for joining the embedded controller on 9124AX?
               - You need to convert them to capwap mode according to
           https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-2/b_Mobility_Express_Deployment_guide/b_Mobility_Express_Deployment_guide_chapter_01100.html#task_CD04E8319602439D973B7D7ACE23111D
 M.
