Can Cisco 1562e APs be daisy chained?
Steven Chobani
I was wondering if Daisy Chaining is supported on the Cisco 1562 APs? I found a reference that said Daisy Chain support for AP 1560 series was added since AireOS version 8.7.102.0. However, I wasn't able to get daisy chaining to work with two of my 1562E APs. I followed the 1532 and 1572 Deployment Guides for their Daisy Chaining instructions.
The setup I followed will be detailed below as well as the physical connection setup. The documentation also had some contradictions specifically in the 1570 deployment guide where it says "Daisy chaining should be enabled on both APs" but a note is later given that says "Daisy-chaining should only be enabled on the slave RAP. The Master MAP should have daisy-chaining as disabled". I tried both configuration setups: 1) master (daisy chain enabled), slave (daisy chain enabled) 2) master (daisy chain enabled), slave (daisy chain disabled). But, still failed to get daisy chaining to work. I wasn't sure if the daisy chaining configuration and physical connection setup would be different for the 1562E?
Physical Connection Setup:
                                                              (master)          (slave)
    WLC <---> Switch <---> RAP <---> MAP1a <---> MAP1b <---> MAP2
                                                         [ Poe Injector ]    [Poe Injector ]
                                                           [Data in]               [Data in]
Daisy Chain MAP Documentation Configuration:
    RAP
         AP Mode: Bridge
         AP Role: RootAP
         Preferred Parent: N/A
         Ethernet Bridging: enabled
    MAP1a:
        AP Mode: Bridge
        AP Role: MeshAP
        Preferred Parent: RAP
        Daisy Chain: enabled
    MAP1b:
        AP Mode: Bridge
        AP Role: RootAP
        Ethernet Bridging: disabled
        Daisy Chain: disabled
    MAP2:
        AP Mode: Bridge
        AP Role: MeshAP
        Preferred Parent: MAP1b
I was wondering if anyone had insight on where I could be going wrong with the daisy chaining setup. Whether it's a problem with the configurations or the physical connections. Or if Daisy Chaining is even supported on the 1562 APs since I wasn't too sure with the available online documentation for the 1560 series other than the Daisy Chain support referenced on the AireOS feature page.
References:
AireOS support: https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/201007-AireOS-feature-list-per-release.html#anc18
1570 Deployment Guide: https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-0/1570-DG/b_Aironet_AP1570_DG.html#concept_85EEB17139E546CB971D47FEBBE86F31
1532 Deployment Guide: https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/7-6/b_1532_dg/b_1532_dg_chapter_01.html#concept_5C8221868DB64B3C85F01162E37F7020
jonssonm1
I see it's been a while with no responses but am wondering if you ever got this figured out.. preparing the the possibility to Daisy Chain some 1562's together and am looking for confirmation from someone who's done it. Any help would be appreciated.
