Can not reach the WLC using Flexconnect AP
pavel.mr4
I am trying to reach the WLC using GUI, SSH and telnet in a Flex Connect environment but i can't, tho i can ping it.
Does anybody have had any similar issue ?
BR!
18 Replies 18
The default gateway for the WLC is 2.2 (the central core switch)?
Can you maybe share some configs to see if something obvious is missing or badly configured?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Can you access the wlc when you are on a wired connection which is on the same subnet as the wireless would be on? This would help isolate the issue especially if you have no issue connecting on the same subnet.
-Scott
StevenH9608
Did you ever figure this out? I am having the same issue. I am using flex connect, and can ping my management interface as well, but still no gui.
