Can static IP be configured for AP3802 ?
Max Maxim
Hi Team,
Possible to configure static IP address  for AP3802 ?
I believe it can be possible ,  but do I configure from WLC or using direct console cable from my personal PC ?
Rdgs
Gary
Sandeep Choudhary
yes you can. Once AP joined to WLC, then you can do it via WLC.
AP#capwap ap ip address <IP address> <subnet mask>
AP#capwap ap ip default-gateway <IP-address>
AP#capwap ap controller ip address <IP-address>
Dont forget to rate helpful posts
Hi Sandeep,
Do you have any cisco doc for reference for complete configuration of Static IP address  setup for AP3800 ?
Maxim
Gary,
Sandeep just gave you the complete method to do the job.
To assign a static IP address, use 'ip address', you can do this for a VLAN in a L2 or L3 switches. In MLS, you can convert a port to L3 port using 'no switchport' then configure an IP address on that physical port.
On the other hand, if you are talking about static route, you can only configure it on L3 switches as L2 switches can't route.
