can the 1550 and 1522 operate in the same mesh configuration?
Shawn Purdy
Have a site that has a 1522 installed. I need to add two new outdoor AP's. Would the 1550 work along with the 1522 or would I have to replace it?
Justin Kurynny
Level 4
Level 4
Shawn,
Yes, the 1550s and 1520s are fully interoperable. I recommend you deploy 1550s at the center (roots) of the mesh and the 1552s at the edge to avoid backhaul bottlenecks.
For current design notes, please refer to:
http://www.cisco.com/en/US/docs/wireless/technology/mesh/7.0MR1/design/guide/MeshAP_70MR1.html
Justin
Surendra BG
Yes u can use.... 1550 is N supported...
Surendra BG
