Can we use a 5508 WLC in Hong Kong and join 3602 APs in Vietnam to it? Any regulatory contraints?
tarun_ladkani
Hi friends,
I am looking for some wisdom here!
Just wondering if I can use a 5508 WLC in Hong Kong and join 3602 APs in Vietnam to it?
Any regulatory contsraints / guidelines that would prohibit from doing so?
- Regards,
Tarun.
Scott Fella
You have two differnt regulations... here is a link:
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps5861/product_data_sheet0900aecd80537b6a_ps10981_Products_Data_Sheet.html
You need to make sure you are not breaking any rules and it is best to have an AP that is specific to that country.  Also if you add multiple country codes on a WLC, the AP's will only be able to use the most common channels and TX power setting allowed on both.  Here is a link explaining that.
http://nostringsattachedshow.com/2012/02/02/multiple-country-codes-with-the-cisco-wlc/
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Leo Laohoo
HKG is -N.
Vietnam is -E.
Tick Vietnam when you configure the WLC and when the AP joins, choose Vietnam (in the Advanced tab).
Sent from Cisco Technical Support Nintendo App
