Can we use Cisco Meraki MR 57 for dual domain access?
sairamprem
Hi Team,
I need a suggestion on the Meraki. Can we use Cisco Meraki MR 57 for dual domain access? As my company is merged with another company and both will sit at a new single place, my boss is asking for this solution for "Single Wi-Fi device for two individual Domain's access", Whereas we are using MR 42 which has single RJ45 POE port, So I searched the Cisco Meraki which shows me MR 57 with two RJ45 POE ports. Request you to explain the possibility options.
marce1000
 - Advising to go  here : https://community.meraki.com/t5/Wireless-LAN/bd-p/wireless-lan
 M.
Rich R
What you are talking about has nothing to do with wireless - that is a NETWORK function.
At the most simplistic level there are various different ways you could do that - by having different SSIDs for different companies.
Or you could have a single SSID used by all users and then provide access to both networks from that SSID but you would be doing that on switches and routers, not APs.
If you get to more sophisticated solution possibilities then you could use an 802.1x SSID which drops the user into the correct company VLAN based on what they login as.
There are really many different ways to do it but it's not the AP you should be focussing on - it's the network design.  Probably best to consult with a network specialist who can examine the 2 networks you want to integrate and suggest options based on the current network designs and requirements.
