Ap doesn't join my controller issue
jpmeunier
Good evening, I'm writing to you because I'm encountering a problem on a small lab I've created to set up a wifi configuration with a terminal. I'm attaching the infra.
A very simple infra, on my level 3 switch I've set up a vlan that I've assigned to all my interfaces in connection with the other equipment
FastEthernet0/1 interface
switchport access vlan 10
switchport mode access
and this for the 3 interfaces, I've also declared a dhcp pool in 192.168.10.0, mask /24, default router 192.168.10.254 (a vlan 10 interface that I've addressed to act as a gateway).
The dhcp config:
ip dhcp pool lan
network 192.168.10.0 255.255.255.0
default-router 192.168.10.254
option 43 ip 192.168.10.1
option 150 ip 192.168.10.1
And the interface declaration
interface Vlan10
mac-address 00d0.9779.8201
ip address 192.168.10.254 255.255.255.0
my machines now receive their dhcp addresses, are in the right address pool and I can ping all the machines from my admin post.
However, when I set up my controller, it doesn't find my terminal, it doesn't connect to it.
I know I'm doing something wrong but I can't find it, I've been pulling my hair out for hours, I hope you can help me.
Thank you very much for your attention and help
Translated with X.X.X (free version)
Haydn Andrews
What config do you have on the WLC
*****Help out other by using the rating system and marking answered questions as "Answered"*****
I configured its ip as 192.168.10.1, gateway interface vlan 10 my level 3 switch, mask 255.255.255.0
Rich R
I think the actual config (show run-config or show run-config startup) from the WLC would be more useful than 2 screenshots from the GUI?
The thing that caught my attention is the software version 8.3.111.0 which is really VERY old - there will have been thousands of bug fixes since that release!
I would first upgrade it to 8.5.182.11 (link below) and then upgrade to current release 8.10.190.0:
https://software.cisco.com/download/home/286312601/type/280926587/release/8.10.190.0
What model of AP are you using?
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
