cannot access web configuration inteface with vwlc using hyper v
Wonxie
Level 3
Level 3
hi
i am trying to follow the official hyper v guide shared here
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-4/b_Cisco_vWLC_on_Microsoft_Hyper-V_Deployment_Guide.html
and demonstrated here
Video demonstration of how to deploy vWLC on Hyper-V:
https:/​/​cisco.box.com/​s/​q5idy5mjj2hxt8etvfjrxwdrgfynafhj
when i try to login using the url it gives me a jumbled up web page and clicking login and entering credentials the screen remains white. no page loads . tried in chrome and ie . i also get error message in IE asking to enable tls 1,1.1,1.2 but that are already enabled.
Wonxie
Level 3
Level 3
Seems like narrowed down the issue.
I can access it via service port interface ip which is bridged to my pc lam card.  And the service interface is set to obtain ip from dhcp.
When I checked in the vwlc controller section it is not detecting other ports. It's only shown one port which is assigned to service port.
I have created amfew virtual switches of type internal, private, external (this time installed Intel dual port gigabit card created two more external switches and bridged to this. And connected both physical interfaces to a dummy switch just to turn on the port.)
Then I assigned a port from each switch but it's not detected and not shown under vwlc controller tab under ports tab.
I have set these settings interfaces as trunk in hyper-v and set native vlan 0, allowed vlan 1-4000
No matter what I do I m unable to make vwlc detect it.
Hyper-v is in server 2012r2.
Same issue with hyper-v on windows 8.1
I did try the configure all in ports section and enabled all but no luck.
Bump
