cannot log into 4400 lan wireless controller
a.ali
Frequent Visitor
Frequent Visitor
i have ( 4404 wireless lan controller) and i lost my data about the management ip and vlan.
i want to reset the controller to default factory, unfortunately i don't have a console cable to log into the controller and reset it.
can i hard reset it in anyway without the need of a console cable ?
Sandeep Choudhary
You have to get console access to reset 4400 WLC.
Here are the process:
1. First, you need to reset the controller. Enter reset system at the command prompt.
2. At the prompt that asks whether you need to save changes to the configuration, enter Y or N, doesn’t matter what you select. The controller will then reboot.
3. When you are prompted for a username, enter recover-config to restore the factory default configuration.
Press enter and the controller will reset back to factory default.
Dont forget to rate helpful posts
