CAP2602
mathurmahesh
Hi ,
I have ordered Cisco CAP2602i access points , the software ordered was MESH ,is there any way we can change the software to RECOVERY after we received the WAP.
Thanks in advance.
Regards ,
mahesh
Rasika Nayanajith
You can add the ethernet MAC address of the AP on to WLC mac filter (secuirty -> MAC filter) & then you can register this AP as a Mesh AP. Then you can change the mode to Local.
Otherwise you can upload the recovery image onto the AP via TFTP. Pls see the below for more detail
http://mrncciew.com/2013/12/13/ap-conversion-using-mode-button/
Rasika
*** Pls rate all useful responses ****
Thanks Rasika, Does Local mode here mean automonous ? or is it the recovery image.
No, Local mode mean the standard Light Weigth Access point mode (Not Autonomous)
Rasika
**** Pls rate all useful responses ****
Try this,
debug capwap console cli
test mesh mode local
Sahil
