Mobile Printer ( Zebra RW420 ) Not Working with Cisco AP
Mohd faraj
Good Morning everyone,
  In cold area -3 inside a warehouse I am trying to connect  a mobile printer ( Zebra RW420 ) to cisco access points of model AIR-LAP1242AG-A-K9  and AIR-LAP1252AG-E-K9  which are woking through WLAN controlar version  6.0.202.0 ,the mobile printer is connecting to cisco AP but shown without IP address , where the IP is configured static , since it's connectiong and working fine with motorola AP .
after upgrading the firmware of mobile printer, I faced the same issue in dry area.
Any ideas please ?
13 Replies 13
Leo Laohoo
Kindly post the output to the command "debug client ".
Can you also post the output to the command "sh interface detailed zebra".
Hi Leo ,
  Kindly find the below results :-
(WiSM-slot4-2) >show interface detailed label
Interface Name................................... label
MAC Address...................................... c4:7d:4f:bd:d4:4b
IP Address....................................... 10.161.20.123
IP Netmask....................................... 255.255.255.128
IP Gateway....................................... 10.161.20.126
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. 502
Quarantine-vlan.................................. 0
Active Physical Port............................. LAG (29)
Primary Physical Port............................ LAG (29)
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. Unconfigured
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... No
Guest Interface.................................. No
(WiSM-slot4-2) >debug client 00:15:70:21:8a:34
(WiSM-slot4-2) >*Dec 24 10:14:44.575: 00:15:70:21:8a:34 Association received fro
m mobile on AP 00:1a:e3:01:84:e0
*Dec 24 10:14:44.575: 00:15:70:21:8a:34 Applying site-specific IPv6 override for
station 00:15:70:21:8a:34 - vapId 6, site 'DC993', interface 'label'
*Dec 24 10:14:44.575: 00:15:70:21:8a:34 Applying IPv6 Interface Policy for stati
on 00:15:70:21:8a:34 - vlan 502, interface id 12, interface 'label'
*Dec 24 10:14:44.575: 00:15:70:21:8a:34 Applying site-specific override for stat
*Dec 24 10:14:44.576: 00:15:70:21:8a:34 0.0.0.0 DHCP_REQD (7) Changing ACL 'none
' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1276)
*Dec 24 10:14:44.576: 00:15:70:21:8a:34 STA - rates (4): 2 4 11 22 0 0 0 0 0 0 0
0 0 0 0 0
*Dec 24 10:14:44.576: 00:15:70:21:8a:34 0.0.0.0 DHCP_REQD (7) Deleted mobile LWA
PP rule on AP [68:ef:bd:2e:7a:10]
*Dec 24 10:14:44.576: 00:15:70:21:8a:34 Updated location for station old AP 68:e
f:bd:2e:7a:10-0, new AP 00:1a:e3:01:84:e0-0
*Dec 24 10:14:44.576: 00:15:70:21:8a:34 0.0.0.0 DHCP_REQD (7) Change state to ST
ART (0) last state DHCP_REQD (7)
*Dec 24 10:14:44.576: 00:15:70:21:8a:34 0.0.0.0 START (0) Initializing policy
*Dec 24 10:14:44.576: 00:15:70:21:8a:34 0.0.0.0 START (0) Change state to AUTHCH
ECK (2) last state DHCP_REQD (7)
*Dec 24 10:14:44.576: 00:15:70:21:8a:34 0.0.0.0 AUTHCHECK (2) Change state to L2
AUTHCOMPLETE (4) last state DHCP_REQD (7)
*Dec 24 10:14:44.576: 00:15:70:21:8a:34 0.0.0.0 L2AUTHCOMPLETE (4) Plumbed mobil
e LWAPP rule on AP 00:1a:e3:01:84:e0 vapId 6 apVapId 1
*Dec 24 10:14:44.576: 00:15:70:21:8a:34 0.0.0.0 L2AUTHCOMPLETE (4) Change state
to DHCP_REQD (7) last state DHCP_REQD (7)
*Dec 24 10:14:44.576: 00:15:70:21:8a:34 0.0.0.0 DHCP_REQD (7) pemApfAddMobileSta
tion2 2514, Adding TMP rule
*Dec 24 10:14:44.576: 00:15:70:21:8a:34 0.0.0.0 DHCP_REQD (7) Adding Fast Path r
ule
  type = Airespace AP - Learn IP address
  on AP 00:1a:e3:01:84:e0, slot 0, interface = 29, QOS = 0
  ACL Id = 255, Jumbo F
*Dec 24 10:14:44.576: 00:15:70:21:8a:34 0.0.0.0 DHCP_REQD (7) Successfully plumb
ed mobile rule (ACL ID 255)
tion2 2630, Adding TMP rule
*Dec 24 10:14:44.576: 00:15:70:21:8a:34 0.0.0.0 DHCP_REQD (7) Replacing Fast Pat
h rule
  ACL Id = 255, Jumb
*Dec 24 10:14:44.577: 00:15:70:21:8a:34 apfPemAddUser2 (apf_policy.c:213) Changi
ng state for mobile 00:15:70:21:8a:34 on AP 00:1a:e3:01:84:e0 from Associated to
Associated
*Dec 24 10:14:44.577: 00:15:70:21:8a:34 Scheduling deletion of Mobile Station:
(callerId: 49) in 1800 seconds
*Dec 24 10:14:44.577: 00:15:70:21:8a:34 Sending Assoc Response to station on BSS
ID 00:1a:e3:01:84:e0 (status 0) Vap Id 1 Slot 0
*Dec 24 10:14:44.577: 00:15:70:21:8a:34 apfProcessAssocReq (apf_80211.c:4391) Ch
anging state for mobile 00:15:70:21:8a:34 on AP 00:1a:e3:01:84:e0 from Associate
d to Associated
*Dec 24 10:14:44.582: 00:15:70:21:8a:34 0.0.0.0 Removed NPU entry.
*Dec 24 10:14:44.586: 00:15:70:21:8a:34 0.0.0.0 Added NPU entry of type 9, dtlFl
ags 0x0
(WiSM-slot4-2) >*Dec 24 10:14:44.591: 00:15:70:21:8a:34 0.0.0.0 Added NPU entry of type 9, dtlFlags 0x0
*Dec 24 10:16:44.550: 00:15:70:21:8a:34 0.0.0.0 DHCP_REQD (7) DHCP Policy timeout
*Dec 24 10:16:44.550: 00:15:70:21:8a:34 0.0.0.0 DHCP_REQD (7) Pem timed out, Try to delete client in 10 secs.
*Dec 24 10:16:44.550: 00:15:70:21:8a:34 Scheduling deletion of Mobile Station:  (callerId: 12) in 10 seconds
*Dec 24 10:16:54.550: 00:15:70:21:8a:34 apfMsExpireCallback (apf_ms.c:418) Expiring Mobile!
*Dec 24 10:16:54.551: 00:15:70:21:8a:34 apfMsExpireMobileStation (apf_ms.c:4427) Changing state for mobile 00:15:70:21:8a:34 on AP 00:1a:e3:01:84:e0 from Associated to Disasso
ciated
*Dec 24 10:16:54.551: 00:15:70:21:8a:34 Scheduling deletion of Mobile Station:  (callerId: 45) in 10 seconds
*Dec 24 10:17:04.550: 00:15:70:21:8a:34 apfMsExpireCallback (apf_ms.c:418) Expiring Mobile!
*Dec 24 10:17:04.551: 00:15:70:21:8a:34 Sent Deauthenticate to mobile on BSSID 00:1a:e3:01:84:e0 slot 0(caller apf_ms.c:4511)
*Dec 24 10:17:04.552: 00:15:70:21:8a:34 apfMsExpireMobileStation (apf_ms.c:4548) Changing state for mobile 00:15:70:21:8a:34 on AP 00:1a:e3:01:84:e0 from Disassociated to Idle
*Dec 24 10:17:04.552: 00:15:70:21:8a:34 0.0.0.0 DHCP_REQD (7) Deleted mobile LWAPP rule on AP [00:1a:e3:01:84:e0]
*Dec 24 10:17:04.552: 00:15:70:21:8a:34 Deleting mobile on AP 00:1a:e3:01:84:e0(0)
*Dec 24 10:17:04.555: 00:15:70:21:8a:34 0.0.0.0 Removed NPU entry.
*Dec 24 10:17:04.568: 00:15:70:21:8a:34 Adding mobile on LWAPP AP 00:1a:e3:01:84:e0(0)
*Dec 24 10:17:04.568: 00:15:70:21:8a:34 Scheduling deletion of Mobile Station:  (callerId: 23) in 5 seconds
*Dec 24 10:17:04.568: 00:15:70:21:8a:34 apfProcessProbeReq (apf_80211.c:4761) Changing state for mobile 00:15:70:21:8a:34 on AP 00:1a:e3:01:84:e0 from Idle to Probe
*Dec 24 10:17:04.788: 00:15:70:21:8a:34 Scheduling deletion of Mobile Station:  (callerId: 24) in 5 seconds
*Dec 24 10:17:04.813: 00:15:70:21:8a:34 Association received from mobile on AP 68:ef:bd:2e:7a:10
*Dec 24 10:17:04.813: 00:15:70:21:8a:34 Applying site-specific IPv6 override for station 00:15:70:21:8a:34 - vapId 6, site 'DC993', interface 'label'
*Dec 24 10:17:04.813: 00:15:70:21:8a:34 Applying IPv6 Interface Policy for station 00:15:70:21:8a:34 - vlan 502, interface id 12, interface 'label'
*Dec 24 10:17:04.813: 00:15:70:21:8a:34 Applying site-specific override for station 00:15:70:21:8a:34 - vapId 6, site 'DC993', interface 'label'
*Dec 24 10:17:04.813: 00:15:70:21:8a:34 0.0.0.0 START (0) Changing ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1276)
*Dec 24 10:17:04.813: 00:15:70:21:8a:34 STA - rates (4): 2 4 11 22 0 0 0 0 0 0 0 0 0 0 0 0
*Dec 24 10:17:04.813: 00:15:70:21:8a:34 0.0.0.0 START (0) Deleted mobile LWAPP rule on AP [00:1a:e3:01:84:e0]
*Dec 24 10:17:04.813: 00:15:70:21:8a:34 Updated location for station old AP 00:1a:e3:01:84:e0-0, new AP 68:ef:bd:2e:7a:10-0
*Dec 24 10:17:04.813: 00:15:70:21:8a:34 0.0.0.0 START (0) Initializing policy
*Dec 24 10:17:04.813: 00:15:70:21:8a:34 0.0.0.0 START (0) Change state to AUTHCHECK (2) last state AUTHCHECK (2)
*Dec 24 10:17:04.813: 00:15:70:21:8a:34 0.0.0.0 AUTHCHECK (2) Change state to L2AUTHCOMPLETE (4) last state L2AUTHCOMPLETE (4)
*Dec 24 10:17:04.813: 00:15:70:21:8a:34 0.0.0.0 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 68:ef:bd:2e:7a:10 vapId 6 apVapId 1
*Dec 24 10:17:04.813: 00:15:70:21:8a:34 0.0.0.0 L2AUTHCOMPLETE (4) Change state to DHCP_REQD (7) last state DHCP_REQD (7)
*Dec 24 10:17:04.813: 00:15:70:21:8a:34 apfPemAddUser2 (apf_policy.c:213) Changing state for mobile 00:15:70:21:8a:34 on AP 68:ef:bd:2e:7a:10 from Probe to Associated
*Dec 24 10:17:04.813: 00:15:70:21:8a:34 Scheduling deletion of Mobile Station:  (callerId: 49) in 1800 seconds
*Dec 24 10:17:04.813: 00:15:70:21:8a:34 Sending Assoc Response to station on BSSID 68:ef:bd:2e:7a:10 (status 0) Vap Id 1 Slot 0
*Dec 24 10:17:04.813: 00:15:70:21:8a:34 apfProcessAssocReq (apf_80211.c:4391) Changing state for mobile 00:15:70:21:8a:34 on AP 68:ef:bd:2e:7a:10 from Associated to Associated
*Dec 24 10:17:06.751: 00:15:70:21:8a:34 0.0.0.0 DHCP_REQD (7) State Update from Mobility-Incomplete to Mobility-Complete, mobility role=Local, client state=APF_MS_STATE_ASSOCI
ATED
*Dec 24 10:17:06.751: 00:15:70:21:8a:34 0.0.0.0 DHCP_REQD (7) pemAdvanceState2 4181, Adding TMP rule
*Dec 24 10:17:06.751: 00:15:70:21:8a:34 0.0.0.0 DHCP_REQD (7) Adding Fast Path rule
  on AP 68:ef:bd:2e:7a:10, slot 0, interface = 29, QOS = 0
*Dec 24 10:17:06.751: 00:15:70:21:8a:34 0.0.0.0 DHCP_REQD (7) Successfully plumbed mobile rule (ACL ID 255)
*Dec 24 10:17:06.756: 00:15:70:21:8a:34 0.0.0.0 Added NPU entry of type 9, dtlFlags 0x0
*Dec 24 10:17:06.756: 00:15:70:21:8a:34 Sent an XID frame
Not getting an IP address because you did not configure the DHCP IP address on the Dynamic Interface.
Hi Leo ,
   Yes  I did'nt configure the DHCP , because I am configured the IP address manualy  in the mobile printers
Please note as I told  in initial comment  all mbile printers are working fine in normal area  except in cold area. I got the recommended from mobile printer vendor to upgrade the firmware , after I doing this on some mobile printers , they are not working in normal area as well as in cold area .
Kindly note the mobile printer is working fine with motorola AP in cold area . also there are others devices like laptops , handled scanners are working fine with cisco AP in cold area .
Thanks ..
In below link the disabling Aironet extensions it sometimes improves the ability of non-cisco client .
So how can disable this feature in WLAN controller 6.0.202.0 ?
http://support.scansource.com/scripts/sseasyfaqs.cfg/php.exe/enduser/std_adp.php?p_sid=VXhj7uEl&p_lva=&p_faqid=4041&p_created=1238533919&p_sp=cF9zcmNoPSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTA0MSZwX3BhZ2U9MTA*&p_li=
To disable Aironet IE, go to your WLAN, edit your SSID, go to Advanced tab.  To the left, there's should be a tick box for Aironet IE.  Un-tick and save.
I disabled this feature , but same no any progress
How many controllers do you have and is the same controller controlling the aps in the same area ? If not, are the wlans configured the same ?
If there is more than one controller make sure the controllers are in the same mobility group. When clients roam from aps on different controller the WLC forwards the client records ..
I have 4 controllers and they are in the same mobility group and the same wlans configuration.
You might also want to turn on passive client feature which is also on the WLAN under the advanced tab.
-Scott
I didn't find this option under advanced tab
Yeah... Didn't see that you were using v6.0 code on the WLC. Maybe look at upgrading to v7.0.x
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70wlan.html#wp1391015
-Scott
  could you let me know to which v7 I should be upgraded  ?
Actually I have controller with v7.0.240.0 in another site , but I didn't find the option , as below shown .
