CAP2602i and 4400 series controller
vancamt76
Can someone tell me if the 2600 series access points are compatible with a 4404 controller running 7.0.235.3 code? I was looking for a compatibilty matrix for the AP to controller to code comparison but couldn't find one.
Scott Fella
It will not work. The 2602 requires the v7.2.x. Here is the matrix.
Hope this helps
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
-Scott
Scott Fella
Hope this helps
-Scott
