captive portal not working for working for apple devices
Anjana A
Hello all,
Please help with the basics check list to be configured on the wlc and ise for the guest captive portal.
Recently we have implemented the guest captive portal, most of the users not able to connect.
Anjana
Mark Elsen
        - Please include wlc model and software version being used ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
  • Is it working for Windows devices?
  • Are you using valid public certificates for your portal(s) which match the DNS FQDN of the site?
  • Have you run a debug/packet capture/radioactive trace on a client experiencing the issue?
  • Have you verified that your redirect ACL (if configured) matches your network as per Cisco documentation?
  • Do you have HTTP enabled under the web auth parameter map or the IP HTTP server?
  • Is captive portal bypass enabled for Apple devices on the WLC?
If you are using C9800 controllers, you can refer to the following links:
Configure CWA:  https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213920-central-web-authentication-cwa-on-cata.html
Tshoot CWA: https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/220852-troubleshoot-central-web-authentication.html
Non-Cisco resources:
https://www.netprojnetworks.com/cisco-9800-with-ise-central-web-authentication/
https://www.wiresandwi.fi/blog/cisco-wlc-9800-cwa-redirection-acl
Jagan Chowdam
/**Pls rate useful responses**/
