CAPWAP-access-point configuration mode
abdulkarim041
Level 5
Level 5
I have a capwap 1702i access point. I have to convert it in automatons mode.  I know the steps but issue is that how i can get the configuration mode of access point. I have connected the console cable to access point after booting  and i am receiving messages like
Not in Bound state.
*Mar 1 00:04:45.611: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
it dont stop.
BR
Abdulkarim
5 Replies 5
lets suppose i have to configure the static IP address to capwap access point.
I connect the console and power up the access point. following messages are appearing.
Cisco IOS Software, C1700 Software (AP3G2-K9W8-M), Version 15.3(3)JN9, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Sat 28-May-16 00:44 by prod_rel_team
Antigua Lite Board P2
40MB format
Tide XL MB - 40MB of flash
Initializing flashfs...
flashfs[2]: 67 files, 9 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 40900608
flashfs[2]: Bytes used: 20854272
flashfs[2]: Bytes available: 20046336
flashfs[2]: flashfs fsck took 11 seconds.
flashfs[2]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 1 seconds.
flashfs[4]: Initialization complete.
Copying radio files from flash: to ram:
Copy in progress...CCCCC
Copy in progress...CCCCCC
Uncompressing radio files...
...done Initializing flashfs.
Radio0 present 8764 8000 0 A8000000 A8010000 0
Rate table has 586 entries (20 legacy/160 11n/406 11ac)
POWER TABLE FILENAME = ram:/U2.bin
Radio1 present 8864 8000 0 80000000 80100000 4
POWER TABLE FILENAME = ram:/U5.bin
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1702I-E-K9 (PowerPC) processor (revision A0) with 376814K/134656K bytes of memory.
Processor board ID FCZ2019T1BW
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 10.2.150.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:78:88:91:CC:00
Part Number : 73-16776-01
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC201346BA
Top Assembly Part Number : 068-05568-02
Top Assembly Serial Number : FCZ2019T1BW
Top Revision Number : A0
Product/Model Number : AIR-CAP1702I-E-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar 1 00:00:16.411: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar 1 00:00:16.871: Registering HW DTLS
*Mar 1 00:00:16.879: APAVC: Initial WLAN Buffers Given to System is 2500
*Mar 1 00:00:16.927: APAVC: WlanPAKs 42878 RadioPaks 42270
*Mar 1 00:00:16.931: Starting Ethernet promiscuous mode
*Mar 1 00:00:19.243: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:19.243: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state to up
*Mar 1 00:00:23.199: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar 1 00:00:23.315: Loading Power Tables from ram:/U2.bin. Class = E
*Mar 1 00:00:23.315: record size of 3ss: 1168 read_ptr: 52B92DE
*Mar 1 00:00:28.355: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4)
*Mar 1 00:00:28.399: Loading Power Tables from ram:/U5.bin. Class = E
*Mar 1 00:00:28.399: record size of vht: 2904 read_ptr: 52B92DE
*Mar 1 00:00:28.403: !!!!!Debug pointer allocated
*Mar 1 00:00:28.555: Wait until the stile protocol list is initialized.
*Mar 1 00:00:29.767: Start STILE Activation
*Mar 1 00:00:31.683: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar 1 00:00:31.683: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to down
*Mar 1 00:00:32.559: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:32.559: %SNMP-5-COLDSTART: SNMP agent on host AP0078.8891.cc00 is undergoing a cold start
*Mar 1 00:00:33.875: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:34.487: [m102x_set_lanport_config] Cannot enable AUX port while POE, connect AC or Inj source
*Mar 1 00:00:34.903: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to uplwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:00:35.059: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:35.059: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:00:36.107: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar 1 00:00:36.107: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar 1 00:00:36.535: %LINK-5-CHANGED: Interface GigabitEthernet1, changed state to administratively down
*Mar 1 00:00:44.899: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar 1 00:00:45.939: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*Mar 1 00:00:47.963: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (2-16)
*Mar 1 00:00:47.963: DPAA Initialization Complete
*Mar 1 00:00:47.963: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar 1 00:00:48.563: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:50.571: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Mar 1 00:00:51.007: Currently running a Release Image
*Mar 1 00:00:51.427: Using SHA-2 signed certificate for image signing validation.
*Mar 1 00:00:51.715: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:58.099: APAVC: Succeeded to activate all the STILE protocols.
*Mar 1 00:00:58.099: APAVC: Registering with CFT
*Mar 1 00:00:58.099: APAVC: CFT registration of delete callback succeeded
*Mar 1 00:00:58.099: APAVC: Reattaching Original Buffer pool for system use
*Mar 1 00:00:58.099: Pool-ReAtach: paks 42878 radio42270
%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar 1 00:01:05.451: AP image integrity check PASSED
*Mar 1 00:01:05.555: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:01:05.555: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
%Error opening flash:/capwap-saved-config (No such file or directory)
*Mar 1 00:01:15.559: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 0 CLI Request Triggered
*Mar 1 00:01:31.327: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar 1 00:01:32.427: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:01:33.427: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar 1 00:01:33.671: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:01:34.671: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
Not in Bound state.
*Mar 1 00:02:15.567: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
My question is how I can enter in configuration mode so that I can type  commands.
 Which key should i press from my laptop?
BR
Abdul KArim
Let's suppose you DON'T.
You see the line that regularly says "Could not discover WLC.  Either IP address is not assigned or assigned IP is wrong.  Renewing DHCP IP address."
You go into configuration mode and configure a static IP address, guess what happens?  The AP will erase it and revert back to DHCP.
The method to use the "Mode" button is fool-proof.  If you know what you're doing, then go ahead.  But if don't (otherwise you wouldn't be asking for assistance) use the "Mode" button method.  It'll save you a lot of time.
Tanks Leo Laohoo,
If you got my issue then kindly let me know how I can enter in configuration mode. I want to assign static IP to access point.
BR
Abdul Karim
Thanks Leo,
actually issue was with my terminal.
BR
