capwap not working
gtstech
Level 3
Level 3
APBC8D.1F82.E7F0#capwap ap ip 172.16.10.200 255.255.255.0 172.16.10.1 IPC socket server not ready for capwapd. Try after few moments, Errno: 2 Msg_id: 11 APBC8D.1F82.E7F0#
20 Replies 20
What is WLC ? Which ver.?
MHM
I want to set the IP address for Access Point IW9165E with the command: capwap ap ip 172.16.10.200 255.255.255.0 172.16.10.1 but it shows the error "IPC socket server not ready for capwapd. Try after few moments, Errno: 2 Msg_id: 11 APBC8D.1F82.E7F0#"
AP Running image: 8.8.1.10
***** show capwap client config *****
IPC socket server not ready for capwapd. Try after few moments, Errno: 2 Msg_id: 31
AdminState : ADMIN_ENABLED(1)
Primary controller name :
Secondary controller name :
Tertiary controller name :
ssh status : Disabled
ApMode : Local
ApSubMode : Not Configured
Link-Encryption : Disabled
Unencrypted Data Keep Alive : Enabled
OfficeExtend AP : Disabled
Discovery Timer : 10
Heartbeat Timer : 30
Syslog server : 255.255.255.255
Syslog Facility : 0
Syslog level : errors
AP join priority : 1
IP Prefer-mode : Unconfigured
CAPWAP UDP-Lite : Unconfigured
AP retransmit count : 5
AP retransmit timer : 3
AP lsc enable : 0
AP Policy Tag : UNKNOWN
AP RF Tag : UNKNOWN
AP Site Tag : UNKNOWN
AP Tag Source : 0
***** show capwap client msginfo *****
Unable to complete request right now. Please retry later.
***** show capwap client rcb *****
IPC socket server not ready for capwapd. Try after few moments, Errno: 2 Msg_id: 10
BLE Module Admin State : Disabled
Error: Socket open failed
***** show capwap client traffic *****
Traffic Statistics for CAPWAP Client
Rx Dot11 Mgmt Pkt : 0
Rx Client Pkt : 0
Rx Host Pkt : 0
Rx Multicast Pkt : 0
Keep Alive Pkts : 0
Rx Action Pkts : 0
Rx Non Dot11 Pkts : 0
Rx Unicast Fail : 0
DTLS Pkts Tx : 0
DTLS Pkts Dropped : 0
Tx Qos Pkts : 0
Tx Non-Qos Pkts : 0
Tx Mdns Count : 0
Total Re-Tx Count : 0
***** show capwap ids sig stats dot11Radio 0 *****
wIDS status for radio 0: disabled
No signatures found.
***** show capwap ids sig stats dot11Radio 1 *****
wIDS status for radio 1: disabled
***** show capwap ids sig stats dot11Radio 2 *****
wIDS status for radio 2: disabled
***** show capwap mcast mgid all *****
mgid wlan_bit_map_all mc2uc_cli mc_only_cl type rx_pak_cnt tx_pak_slot0 tx_pak_slot1 tx_pak_slot2 tx_pak_slot3 tx_pak_rlan
***** show capwap mcast mgid clients *****
Client for each MGID:
mgid type client slot vap
MGID for each Client:
client ip port mgid
"Every time I use the capwap command, it says "IPC socket server not ready for capwapd. Try after a few moments, Errno: 2 Msg_id: 3
Unable to complete request right now. Please retry later."
Bullsh*t!
An IW9165 running 8.8.1.10?   Suuuuuuuuuuuuuuure.
Sure
@gtstech
 Is this AP really capwap? Can I see the "show version" command?
Show version
show running-config
@gtstech
 From the show version command, we can see   ap1g6b
 This code tells us that the AP is running AP-COS which is similar to clickOS or IOS.
These APs and software are pretty new to everyone and cause trouble. I am not sure if you have the command "ap-type capwap" available on there, if you do, that could be one way out.
If not, maybe you need to get a different firmware version in order to add this AP in the WLC.
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9120axi-access-point/217537-repairing-c9120-c9115-access-points-from.html
""ap-type capwap" I tried and it gave me an error "IPC socket server not ready for capwapd. Try after a few moments, Errno: 2 Msg_id: 3
and I tried to update the firmware version with the command "archive download-sw /reload tftp:" but it didn't work. I pinged the PC to the AP.
"The Cisco Catalyst IW9165E Rugged Access Point and Wireless Client (hereafter referred to as IW9165E) is designed to add ultrareliable wireless connectivity to moving vehicles and machines. The IW9165E runs Cisco Ultra-Reliable Wireless Backhaul (Cisco URWB), which delivers high availability, low latency, and zero packet loss with seamless handoffs.
The IW9165E can also operate as a Wi-Fi client in Workgroup Bridge (WGB) mode, which allows it to connect to a Cisco access point infrastructure, and Universal WGB (uWGB) mode, which allows it to connect to a third-party access point infrastructure. Both of these modes help bridge the wired clients that are behind the WGB to the access point on the infrastructure side."
I start to think that this AP is not for normal AP usage.
 But, I am not sure. Best way to figure out. Put this AP in the same network as the WLC or connect It to a network with DHCP with option 43.
If by any chance this is made to work with WLC , It Will Join. But, as per documentation this seems to be made for backhau and wgb
What I read here is "You need to choose the image to boot up with according to the mode your AP is running, CAPWAP or URWB."
https://www.cisco.com/c/en/us/td/docs/ wireless/outdoor_industrial/iw9165e/software/configuration/b-iw9165e-scg-17-14/m-introduction.html
I upgraded to new OS 17.15.1.4 but it reported the error below
