02-23-2012 09:06 AM - edited 07-03-2021 09:38 PM
After going to the High Availability Tab in the WLC GUI and setting the primary, secondary, and tertiary, how do you see that in the CLI in the AP?
I tried using show capwap ip config, it doesn't show any entries at all?
And also, is there a command to do that in the CLI in the AP? to set the primary, secondary, and tertiary?
Thank you.
Solved! Go to Solution.
02-23-2012 10:37 AM
sorry, missed the 'in the AP cli' part.
you can't set the information from the CLI on the AP, that has to be done on the WLC.
if you do a
show capwap client rcb
that shoudl show you what WLC the AP is configured for
Steve
02-23-2012 09:20 AM
you should be able ti see that with
Show ap config general
Steve
02-23-2012 09:41 AM
You can set the primary, secondary and or tertiary from the ap if the ap has not joined by doing:
capwap ap controller ip address wlc-mgmt-ip
If the AP's are joined to the WLC then issue:
config ap primary-base
02-23-2012 10:30 AM
show ap config general
% Invalid input detected at '^' marker.
config ap
Getting invalid commands for the both of them. Below is IOS version the AP is on.
Cisco IOS Software, C1200 Software (C1200-K9W8-M), Version 12.4(21a)JHA, RELEASE SOFTWARE (fc3)
02-23-2012 10:32 AM
you need to run th config ap... from a WLC. You have autonomous AP's so you need to convert them to LWAPP and you also need a WLC to do this.
02-23-2012 10:46 AM
"ou need to run th config ap... from a WLC. You have autonomous AP's so you need to convert them to LWAPP and you also need a WLC to do this."
It's been converted to LWAPP, but haven't joined a WLC yet.
What I wanted to do was configure a primary, secondary before joining it to a WLC.
Because what I would of done is first have it join a controller, then go into the GUI and change the HA (High Availablilty) and add the primary/secondary controllers.
Thought if I could skip the first step and try to configure it from the AP.
02-23-2012 10:37 AM
if you do a
Steve
02-23-2012 10:49 AM
Ah, in that case that means I have to have the LWAPPs join the controller first before issuing the commands on the WLC.
Ok, that clears up some things.
Thanks.
02-23-2012 01:58 PM
The command "sh ap config general
02-23-2012 03:13 PM
is there a way to show the primary/secondary on the AP as oppose to the WLC?
02-23-2012 03:19 PM
No because the WAP does NOT keep these information. The only "information" the WAP keeps is a simple stuff on WHERE the WLC is. It's like ET-phone-home.
02-23-2012 08:31 PM
Actually, the same "#show capwap client rcb" at the AP CLI that Steve suggested should reveal this information.
