Catalyst 9100 Embeded Wireless Controller AP and Cisco ISE Config
amalmichaelvj
Hello Cisco Team,
Can anyone share Cisco Catalyst 9100 EWC access point configuration for Cisco ISE. We have a Cisco ISE in network. Cisco ISE need to authenticate network devices. Then only we can configure Wireless Network.
Please share configuration examples or Commands if possible.
Scott Fella
EWC controller has the same configuration as the 9800 controllers.  So for TACACS and or Radius,you can follow the 9800 guide if there isn't a specific guide for the EWC.  Here is a link for TACACS:
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/214490-configure-radius-and-tacacs-for-gui-and.html
-Scott
Scott Fella
Keep in mind that you will find additional info if you search "Cisco 9800 TACACS ISE".  Here are some blogs with additional info.  You will need to go through the Cisco docs along with some blogs to get a better understanding of what you need to do for your requirements.
https://mrncciew.com/2022/05/27/9800-tacacs/
http://www.netprojnetworks.com/cisco-9800-tacacs-config-cli-and-verify-notes/
-Scott
Mark Elsen
                                                   >...Cisco ISE need to authenticate network devices.
 - In principle this topic is 'out of the EWC' and or the access points can be configured as allowed network hosts through MAB-authentication with vlan-assignment  on ISE (for instance) ,  stronger mechanisms in combination with the controller are for instance show in :
                , https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213916-catalyst-9800-wireless-controllers-ap-au.html
                  https://www.labminutes.com/wl0047_9800_wlc_access_point_authentication_2
                                        EWC or 9800 is equivalent for this topic ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
