Catalyst 9115AXI Update Firmware
Hello Community,
I have many Catalyst 9115AXI some of them are running good version and other with old firmware version
I want align all AP to same version to be compatible with the WLC (I had 9800), I download the firmware but I don't know ho to  push the new firmware,
I have Console Access to the AP (I don't know how to enable GUI or SSH on the AP)
any suggestion please ?
balaji.bandi
Better to setup a test environment, and use WLC 9800 - use option 43 to join WLC - so AP automatically update required software.
we use generally Cat 9300 48 port switch - connect 48 AP so they update and provision Automatically using WLC controller - this is best rather doing each AP.
BB
Leo Laohoo
Upgrade the firmware of the 9800 (do not forget the SMU and APSP) and the controller will push the firmware down to the APs
great,
that's work
the WLC take about 20 minute to update the firmware to the right and recommander version
Thank you for your support
