Hi all,
After adding a 9800-CL to Prime I got a critical alarm. Does somebody know the reason for this?
Catalyst 9800 Telemetry coral connection failure for device IP 10.1.51.11. Please check the coral connection.
Many Thanks!
Regards, Urs
- Does your Prime version (including device packs if needed) ; support the catalyst 9800 ?
M.
The alarm showed up right after installing Patch2 and the actual Device Pack.
- If the Device Pack should support or is intended to support the 9800 consider this being a bug , report to TAC.
M.
I have the same problem.
device packs are not available
to my infrastructure, I have a fresh installation of cisco prime infra. 3.6 und the cisco wlc 9800 16.10.01e (recommanded by cisco)
thanks and regards..
Same here with
"Catalyst 9800 Telemetry coral connection
failure for device IP x.x.x.x. Please
check the coral connection."
Prime Infr. Build 3.8.0.0.310, PI 3.8 Update 02, Prime Infrastructure 3.8 Device Pack 1
and
C9800-CL 17.3.1
Controller listed in Prime but were are no APs from that wlc.
For 17.3 you need PI 3.8MR1 - as documented on the release notes
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-3/release-notes/rn-17-3-9800.html
We have a EFT image we can give you. You can contact your account manager to sign you in or open a TAC SR so we can give you the link.
Thank you for reply,
after my post, we've seen in
, too, that we have to wait for MR1 release. Could you mention a release date for the MR1?
we run into the same issue PI 3.8 Patch2
is there an ETA for the official release date for MR1?
it is there since September https://software.cisco.com/download/home/286325039/type/284272933/release/3.8.1
with 3.8.1 MR1 (installed in September) everything runs fine in our installation. Controller and APs shown in Prime.
Thx and Regards.
