CCM 4.2 Changing code pin minimum size
ccr_cisco
Level 2
Level 2
Is there's a way to change the minimum size of the user's code pin from 5 to 4 caracters.
Thanks for your answer
Rob Huffman
Hi Morgan,
Here is a good Cisco tech note that describes the process required to change the minimum Pin length;
DC Directory: Modify the Default User PIN and Password Length
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a00805ca029.shtml
Hope this helps!
Rob
Please remember to rate helpful posts.....
Thanks for your answer but I have an active directory integration so I think this technote is not the good one.
Is there the same procedure for AD.
Rob Huffman
Hi Morgan,
Sorry about that 🙂 Have a look at this recent post that relates to AD rather than DC Directory and the good answer from Gonz @ Cisco Systems;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dde91ce/0#selected_message
Hope this helps!
Rob
