CDMA remote antenna
mx
Level 5
Level 5
Hi. I have a 2800 with a 3G-CDMA hwic in it but service isnt terrific. If I move it outside then its great. So what I need to do is find an external weatherproof antenna but am having no luck. This document shows acceptable cables and antennas but the antennas it shows are indoor use only.
http://www.cisco.com/en/US/docs/routers/access/1800/1861/software/feature/guide/3hwicdma.html#wp1146724
Any ideas appreciated, thank you!
Bob
dennischolmes
Level 11
Level 11
Contact TESSCO and ask for the CDMA external antenna that are vehicle mounted for the 3200MAR. You can use these antennae outdoor.
