Ceiling Mount Kit
Gene Erickson
Community Member
In looking at the User Guide for the AIR-ANT5160V-R, it mentions a Ceiling Mount Kit which includes these items:
•One T-rail grid bracket
•One bracket plate
•Two internal tooth lock washers
•Two #6-32 x 1/4-in. SS Phillips machine screws
•One I-beam clamp
•One 1/4-in. flat washer
•One 1/4-in. split lock washer
•One 1/4 x 20 x 1/2-in. hex head bolt
Can these Items be purchased separately?  I am in need of a device to mount another Omni-Directional "Mast-Mount" antenna to a steel I-beam (not a Suspended Ceiling, but the Structural I-Beam of the building.  This I-beam Clamp looks like it would work but would like to have all the hardware.  WHat is the part number for thei kit, or do you have a 2.4GHZ antenna that also has this mounting hardware?
