12-15-2014 06:46 PM - edited 07-05-2021 02:08 AM
Scenario:
Replacing 4404s with 5508s.
Primary 4404 carried all the load. Secondary does nothing.
New 5508.
Primary 5505 carries all the load. Secondary does nothing.
Can I copy the old configs for multicast to the new WLCs without issue? (even if old WLCs are online?)
Solved! Go to Solution.
12-15-2014 06:58 PM
No, that is used for WLC to AP communication in multicast method. So you should not have any problems.
Anyway to be 100% safe, change it or disable this multicast method in your old WLC.
Rasika
*** Pls rate all useful responses ****
12-15-2014 06:51 PM
If you want to keep the same address copy it to 5508 & change the old WLC multicast address. Each WLC should have unique multicast address to prevent any possible complications.
Rasika
12-15-2014 06:54 PM
If the old WLCs had no APs, could there be an issue?
12-15-2014 06:58 PM
Rasika
