Certificate between Access point and Wireless client
csco11030279
Level 3
Level 3
Hi;
is there anyway to configure a certificate between the wireless AP and clients to secure my username and the password.
my setup is WLC5508/AP1142/ACS5.4
I need the client to trust  the certifcate before entering the UN/PW
6 Replies 6
Chris Illsley
Level 8
Level 8
It what authentication are you using?  If you are using a RADIUS server typically the certificate will be installed on the RADIUS server.
Let me know and we should be able to work it out.
Cheers
Chris
that is true, I am using RADIUS server for the authentications ; we are useing WPA2/WPA1
Thanks for the greate information
That's fine then, the certificate gets installed on your RADIUS server.
Register it in DNS make sure you have the trusted roots intalled and you should be good to go.
Chris
Edit:  It's simple enough to generate the CSR in ACS 5.
http://www.cisco.com/en/US/products/ps10315/products_configuration_example09186a0080b4cdb9.shtml#compdomain
I found this link, but in this procedure the computer or the wireless client should be part in the domain.
is this the only way to do that, ?
Not read it, but if you are authenticating against AD you do need an object in the domain to authenticate against, be that a computer or a username, the certificate part though has nothing to do with the domain.
Chris
Abhishek Abhishek
As per your query i can suggest you the following solution-
LAP authorization can be performed in two ways:
  • Using the Internal Authorization list on the WLC
  • Using the MAC address database on an AAA server
The behaviors of the LAPs differ based on the certificate used:
  • LAPs with SSCs—The WLC will only use the Internal Authorization list and will not forward a request to a RADIUS server for these LAPs.
  • LAPs with MICs—WLC can use either the Internal Authorization list configured on the WLC or use a RADIUS server to authorize the LAPs
This document discusses LAP authorization using both the Internal Authorization list and the AAA server.
For more information refer to the link-
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a00808c7234.shtml
http://technet.microsoft.com/en-us/library/cc759077(v=ws.10).aspx
Hope this will help you.
