Certificate for Web Auth
saleem pc
Level 3
Level 3
We are planning to install Certificate signed by CA Auth to install in Cisco WLC 5520. The present Web AUth URL for Guest Wifi is https://virtual IP
I understand the web url should be hostname.domainname inorder the certificate to work. how I can convert the web authentication URL to DNS.
Many thanks
Saleem
Sandeep Choudhary
The WebAuth URL is set to 1.1.1.1 in order to authenticate and the certificate is issued (this is the CN field of the WLC certificate). If you want to change the WebAuth URL to 'guest.XYZ.com', for example, go into the virtual interface configuration (the 1.1.1.1 interface) and there you can enter a virtual DNS hostname, such as guest.XYZ.com. This replaces the 1.1.1.1 in your URL bar. This name must also be resolvable.
Dont forget to rate helpful posts
Sandeep Choudhary
