certificate issue joining AP to vWLC
fcorfdir
I just install the new cisco virtual Wireless controller, and I try to join an lap 1042 to it but i receive this error:
Sep 13 04:58:43.000: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
Sep 13 04:58:53.008: %CAPWAP-3-ERRORLOG: Go join a capwap controller
Sep 13 03:59:51.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.41.253 peer_port: 5246
Sep 13 03:59:51.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
Sep 13 03:59:51.014: %LWAPP-3-CLIENTERRORLOG: Peer certificate verification failed
Sep 13 03:59:51.015: %CAPWAP-3-ERRORLOG: Certificate verification failed!
Sep 13 03:59:51.015: DTLS_CLIENT_ERROR: ../capwap/capwap_wtp_dtls.c:333 Certificate verified failed!
Sep 13 03:59:51.015: %DTLS-4-BAD_CERT: Certificate verification failed. Peer IP: 172.16.41.253
Sep 13 03:59:51.015: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 172.16.41.253:5246
Sep 13 03:59:51.016: %DTLS-3-BAD_RECORD: Erroneous record received from 172.16.41.253: Malformed Certificate
Sep 13 03:59:51.016: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.16.41.253:5246
I have already verify the time config on the WLC. I have try 2 LAP but same issue.
Cisco IOS Software, C1040 Software (C1140-RCVK9W8-M), Version 12.4(23c)JA, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 01-Jun-10 12:53 by prod_rel_team
ROM: Bootstrap program is C1040 boot loader
BOOTLDR: C1040 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA3, RELEASE SOFTWARE (fc1)
AP5057.a87b.44e4 uptime is 8 minutes
System returned to ROM by reload
System restarted at 03:54:24 UTC Thu Sep 13 2012
System image file is "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1042N-E-K9    (PowerPC405ex) processor (revision B0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1614W572
PowerPC405ex CPU at 333Mhz, revision number 0x147E
Last reset from reload
LWAPP image version 7.0.94.21
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 50:57:A8:7B:44:E4
Part Number                          : 73-14034-04
PCA Assembly Number                  : 800-34273-05
PCA Revision Number                  : A0
PCB Serial Number                    : FOC16091WYH
Top Assembly Part Number             : 800-34285-03
Top Assembly Serial Number           : FCZ1614W572
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1042N-E-K9
Configuration register is 0xF
17 Replies 17
Try to disable the hash in cli
config certificate ssc hash validation disable
dwaters
I now have an LAP1131AG (eBay for £60) working on my vWLC without the use of first assigning it to a physical WLC running 7.3 code as everyone keeps mentioning.
My vWLC is running 7.3.101.0
Now the most important bit: the Cisco website mentions under its Latest Releases for my 1130 series AP “12.4.10b-JDA(ED)” (03-Nov-08) THIS IS NOT CORRECT! There is a later version than this named “12.4.25e-JAL(ED)” (04-Sept-12) << this is the one you need!
Download “c1130-rcvk9w8-tar.124-25e.JAL.tar” and upgrade; I didn’t use the Upgrade Tool, admittedly the AP did come preconfigured with an LWAPP image (quite old). I just used the general method of renaming the file to .default, changing your IP address to 10.0.0.2/8 etc and using the MODE button.
Changed the mode to Flexconnect, which I believe is the new H-REAP and were off! Serving SSIDs and working without faults •J (I believe I may have played with Certificates also)
I hope this helps everyone and saves them the few hours this cost me •J
P.S. I have some 1200 series, AKA 1200, 1231, 1232, these do not work! However 1240’s do •J
Cheers! Dan.
Joseph Janning
I also realize this very old but recently ran into the problem after a power outage caused the WLC to reboot.  Turns out the time in the controller was off by 8 years.  Fixing the time registered the APs immediately.
