Certificate requirements for temeletry (Aireos)
LKL4
Hello guys,
We are trying to connect the Cloud Services (telemetry) of our aireos controller (8540 - version 8.10.171) to a influxdb server and that influxdb server are connected to a grafana. We have performed all of that steps and topology based on this guide (https://www.wifireference.com/2020/01/14/viewing-network-telemetry-from-the-catalyst-9800-with-grafana/#Graphing_Channel_Utilization), so, now we are in the step of the connection between controller and influxdb, but, the controller are warning that message for us "Peer certificate cannot be authenticated with given CA certificates, SSL certificate problem: self sign". Anyone know how to solve this? If we install just a WebAdmin certificate in the controller we can fix that warn? This certificate is needed just in the controller side or influxdb too?
Any help will be appreciated, thanks!
Prince.O
Based on the error "Peer certificate cannot be authenticated with given CA certificates, SSL certificate problem: self sign". Is this error seen on the wireless controller or influxdb ?
- If the controller, this points to the controller stating the influxdb is using a self signed certificate that is not trusted as it can't verify the cert. I would suggest installing a 3rd party trusted cert signed by a trusted CA on the influxdb so the controller can verify it.
Hello @Prince.O ,
Thats the error seen on WLC:
And thats the error seen on InfluxDB:
[33661]: ts=2023-03-08T18:26:38.023703Z lvl=info msg="http: TLS handshake error from 10.1.2.22:53667: remote error: tls: unknown certificate authority" log_id=0gScKP_G000 service=http
I already looked in the controller docs, but I didn't find anything about the certificate requirement for this communication. If anyone has any info about how to resolve that issue, I appreciate it.
Scott Fella
That would be interesting if you get that to work.  I know that folks have setup TIG's to get streaming information from the controller. AireOS doesn't do subscription, so just curious what data you will be getting.
-Scott
