certificate with acs
y.johnny
Hi all
I am trying to connect wireless client to access-point using eap-tls and acs ver 3.1 .
When I try to obtain a certificate from a Microsoft win2k certificate server
From a windows xp client (with embedded ie 6.0 ) I have a massage :” downloading activex control”
Even if I lowering security option in the ie it still appear.
Other clients with ie 5.0 ( win2k) are ok
mcnaz-yeo
Update this patch at your cert server patch Q311401 to resolve your active X problem
McNaz
thank's
it's working fine now
This is exactly what i'm trying to acheive. Are you using a win2k active directory server domain, if so, is it possible to acheive this without one?
Yes , it is posible to install a certificate without active directory
and it is working grate
